so my timing belt didnt fail but something worse
now that the shop i had to take my car to has finaly got around to my car found what failed in the motor. apparently the chain tensioners guide broke apart and it locked up the top end and sheared the key on the tb gear. which explains the turning over with no compression like a broken tb. now the mechanic said that the root cause he has seen something like this would be a lack of maintance or even possiblely someone put in the wrong oil, im thinking probably both. but has anybody had this happen before, is this kinda common or is just a oddity?
You'd have to run a bad cam chain tensioner for a long time before it caused the chain to slip or snap. Surely there were other symptoms before this happened.. Like a loud screech/rattle/chain slap sound that varies with rpm... A bad cam chain tensioner usually means the lifters are having a hard time getting oil to the top of the engine, which usually means oil sludge.
he showed me the head and it did have a small amount of sludge build up. but the tensior made no horrible noise, ive heard way worse chain slack from my 85 toyota pickup that i use to own. it only made a slight noise on idle which went away after it warmed up. now another question, since there was sludge build up in the top end i would imagine theres some in the bottom and whats the best way to get it out. are there engine oil treatments that i could use?
i know the cams were in good shape, im not sure bout the bearings tho. the head didnt have a thick amount sludge it was just more like a film. hopefully i can have it back before the end of next week, i havent had it for almost 2 months now.
Yeah if the cam lobes look alright then thats the best way to know. The main problem is the oil pickup screen is restrictive and sludges up too easily. Best thing to do is on time oil changes and use the big oil filter. Maybe a seafoam treatment to the crank every 3rd or 4th oil change.
the parts were on order last week and should have been in on friday, and the price isnt of much concern since the dealer i bought it from is paying for most the damage. ill plan on doing a seafoam treatment as soon as i get it back and then a few more down the road. i wouldnt think theres different sized filters but the two i have (audi and a mobil) are huge compared to the ones i use on my SBC in my pickup. but thanks for all the help guys!
Audiguruforyou
09-20-2011 01:31 AM
Jeffla
01-03-2010 04:43 AM
fritz
08-12-2007 02:55 PM
