Then if is a member it should give out some discount on that software or some incentive 100 is a little to pricey if you agree
Jumpin' Jesus on a pogo-stick
just use the lite version if you don't want to pay. it will still do just about everything you want it to do for FREE. If you can't pony up $100 bucks for a license you should probably just sell your car. |
I am trying to use the lite version now but i will need some advice
Ok so it can de the radio but nothing else it keep saying no response from controler
You should try searching, this has all been covered..
i searched but nothing even resemble my problem i have a vag-tool 409.1 usb running vista 64bits
but if this thing would not be compatible i should not see anything but this only shows me the radio and on the rest no response from com why is that ? |
Vista is the problem. Others who have tried using it haven't had any luck. And nothing says Uwe should be giving a discount. It's his work and he can charge $500 if he wants. It's everyone's choice whether to buy it.
i understand but they state on ross-tech website that the software is vista win7 32-64bits supported and it is not , even if i pay 99 for this i have to test`it first and i can`t do that
Did you pick a COM port between numbers 1-4 and set your USB device to that within Windows? You have to setup the configs in Windows and within VAG-COM to use the same COM port.
Originally Posted by jdahlen24
(Post 1285459)
