Someone heard of this craziness?
Old Jun 23, 2011 | 06:03 PM
patrixx006's Avatar
Default Someone heard of this craziness?
okay so im sure you know that i have had this crazy starting problem with my car lately and cant get it resolved. CVBADASS also had this problem but fixed it by changing his ecu relay #30... so i went and bought the relay and when i went to replace it i have relay #429 in its place. So i called up the stealership and they said "that relay is only for an a6 and the correct one is # 30". So i put in relay # 30 and my car wont start at all with that relay. does anyone know anything about this?
Old Jun 23, 2011 | 06:16 PM
NickBroderick's Avatar
Your car is really an A6. That's all I can think of.
Old Jun 23, 2011 | 06:30 PM
Double post. -_-
Old Jun 23, 2011 | 06:37 PM
patrixx006's Avatar
i thought of that to.... is there any way to change that?
Old Jun 23, 2011 | 11:08 PM
cvbadass's Avatar
I feel your pain! The dealership told me to replace my ignition switch, and if that wasn't the problem, then it would be the relay. I did change the ignition, but that wasn't my problem, it was the relay. Maybe for you it would be the ignition switch.
Old Jul 26, 2011 | 06:55 PM
RKOOOO's Avatar
Have you fixed your starting problem yet? I have the same deal going on (no relay #30) and I've changed... The Mass Airflow sensor,coolant temp sensor, spark plugs, all filters and my fuel press is good.
Old Jul 27, 2011 | 08:15 AM
cvbadass's Avatar
You could try the ignition switch.
Old Jul 27, 2011 | 02:49 PM
patrixx006's Avatar
no i have not fixed it yet... im thinking injectors and coils next seeing that i had misfires in cylinder 3 and 4 when i replaced that relay
Old Jul 27, 2011 | 10:56 PM
RKOOOO's Avatar
Something I found out that narrows my search (I think) to a sensor.... When I had the Mass airflow sensor unplugged I started the car and it fired right up. so I'm thinking when the ECU uses a default fuel air mixture it works. give it a try on yours and see what happens. I was thinking the ignition switch but it fires right off 100% of the time if its been started within the last few hours.
Old Jul 27, 2011 | 11:36 PM
TaConklin's Avatar
Yeah just buy an A4 logo from the dealer, that should do it.
