Soo much info on this, none applies to me
Old Dec 2, 2009 | 09:49 PM
audirpm's Avatar
Default Soo much info on this, none applies to me
Alright heres the problem. Ive got auto dimming mirrors. Both side mirrors pass and driver side works correctly. Whenever a headlight is shown in the rear view mirror the side mirrors will dim. The only problem is that the rear view mirror does not dim. It stays completely un-dimmed if you will while the side mirrors dim very much. Any ideas here? I am sure im looking at a new rear view mirror, I just have never noticed any fluild leaking from the rear view. And I would figure that if there was an actual issue with the rear view mirrors that the sides wouldnt work. Advice if any would be helpful. Thanks a bunch.
Old Dec 2, 2009 | 09:56 PM
Andrew149's Avatar
you are prob looking at a new one i know its a very common issue i drove one with only 60,000 miles that had the same issue and it was a 01 i think the replacement is like $1200 not worth fixing
Old Dec 2, 2009 | 10:22 PM
audirpm's Avatar
BTW im glad that you love to respond to my threads . Very helpful in most cases. You've seen a case where the rear view mirror doesnt dim but the side mirrors do? And you think its gonna cost $1200 for a rear view mirror? Im also a little confused, considering i know the sensor works since the side mirrors work correctly. I thought i've heard of people getting auto dimmer rear views from shokan.
Old Dec 2, 2009 | 10:31 PM
Andrew149's Avatar
i have not seen that case ive seen the case where the mirrow is like leaking and you can see it at a certain angle its possible theres a fuse for that mirrow have you tried vag-com or anything like that maby it will mention that theres a no response to the unit
Old Dec 2, 2009 | 10:36 PM
Andrew149's Avatar
oh its only $319! huh this dude told me it was $1200 to fix haha what a lier heres the link
http://www.ecstuning.com/Audi-B5_A4-...or/OEM/ES4163/
Old Dec 2, 2009 | 10:50 PM
audirpm's Avatar
hah thanks for the update. I would agree that 350 is more reasonable. Still would like some input if anyones got any as to a fix or solution short of buying a new mirror.
Old Dec 2, 2009 | 10:54 PM
Andrew149's Avatar
yep i know what you mean dont spend the money unless u have it and if u haft too i think you will be able to live with the mirrow like that but hmm have you bought vag com yet? most of the people on here have like 97-99 and that mirror occured in 99.5 and im a 99 so i can only go so far with you.
Old Dec 2, 2009 | 11:20 PM
audirpm's Avatar
Ya i've got vagcom. I'm actually work on audi's. Well mostly Porsches, but audi's and VW's as well. I find that some of these weird audi quarks are easier to diag. through the audi forums. Not a HUGE fan of using computers to diag. stuff but technology is changing i suppose i should get with the program.
Old Dec 3, 2009 | 12:13 AM
airguard350's Avatar
Tech Guru
My sideviews dim but my rearview doesn't. If the rearview has that **** right under it or there are no wires running from the roof to the mirror than your rearview is not auto-dimming.
Old Dec 3, 2009 | 03:39 PM
Andrew149's Avatar
Yeah ive worked on a porsche befor older ones but this stuff is so similuar
