Sparks plugs
I was told to get NGK BKR7E spark plugs for the speed tuning chip. But I cant find them anywhere. Is there any other kind that will work good, because my car is misfiring bad
http://www.intengineering.com/Shop/C...id/0/SFV/32093
try your local parts store, like autozone, the one by my house has them so maybe your local store will to |
Read the plugs, you now have, to make sure they're white.
If they are white, running hot, get 7s. www.ecstuning.com |
Ok so I changed the sparks and it runs good now, went to clear codes and I got p0106 Manifold Abs.Pressure or Bar.Pressure Range/Performance. anyone know what this could be?
Clear the code and see if it returns. You might have to check
with Revo, if it returns. |
sounds like your boosting more than what your car is used to and the MAP sensor threw a code. just clear it and see if it returns
