squeeky noise while im driving...
Old Apr 28, 2008 | 05:21 PM
tab667's Avatar
Default squeeky noise while im driving...
hey guys, i gotta a question about the squeeking grom my wheels "i think", while im driving. i can hear it when go really slow 1st and 2nd gear up and especially when im turning. then it stops when i go faster then 20 mph, so u guys have any idea what that might be? i had my serpentine belt changed, a month ago. is it a bearing? one time i didnt use a car for 4 months and when i took it on the road, i had this weird noise coming from the back, but it dissapeared after a few minutes of driving, anyway thanks for your time guys.
Old Apr 28, 2008 | 05:35 PM
a4b5guy's Avatar
Default RE: squeeky noise while im driving...
The car that sat was probably rust on the brakes. Does it do it when you reverse also?
Old Apr 28, 2008 | 06:20 PM
tab667's Avatar
hmm. no i dont think so. only when i go forward, and when im turning, when i keep the wheel completely straight it stops.
Old Apr 28, 2008 | 09:20 PM
a4b5guy's Avatar
Does it do it only when you turn one direction and not the other. This would be an indicator of a wheel bearing going bad. But you said it goes away when you go faster so that kinda removes that possibility. Can you tell what side it is coming from?
Old Apr 29, 2008 | 05:13 PM
tab667's Avatar
its hard to say. im inside the car when it happens. how can i check if thats a bearing?
Old Apr 29, 2008 | 05:31 PM
chaos92287's Avatar
if its only making the noise while turning one direction its a wheel bearing. if it make the noise turnign the wheel both ways its either a cv boot or tie rod. visually inspect the cv boot and if its not torn, then its most likely your tie rod end
Old Apr 30, 2008 | 05:10 PM
tab667's Avatar
ok i ll check that, thanks for your time man.
grkmchn
Mar 11, 2009 10:26 PM
nmocci
Oct 22, 2008 02:23 PM
lnewman
Apr 13, 2008 03:16 PM
coupe16v
Oct 19, 2007 09:38 PM
ironman
Apr 18, 2007 05:49 PM
