Starter Compatibility
Old Nov 27, 2008 | 01:30 PM
eben80's Avatar
Question Starter Compatibility
Hi all,
I need to replace my starter on my '97 A4 Avant ACK 30V V6.
The problem I have is that there seems to be more than one option available to me because my VIN falls in a "grey" area.
VIN = wauzzz8dzva083765
According to ETKA I should be using either 078911023X or 078911023
Are these starters compatible with the spare 078911023D that I have?
What is the difference?
Thank you in advance.
Eben
Old Nov 27, 2008 | 02:58 PM
ghost6303's Avatar
well look at your vin...
WAUZZZ 8D Z V A 083765
ETKA says that you need the first one (1) if your VIN is 205000 or lower.
you need the (1A) one if your vin is 205001 or higher.
083765 is lower then 205000
Old Nov 27, 2008 | 03:29 PM
eben80's Avatar
Yes I got that part but just wanted to know if the later model starter would fit. Mounting holes seem the same its just the "nose" that has been strengthened.
Old Nov 27, 2008 | 03:41 PM
ghost6303's Avatar
ETKA makes the distinction for a reason. if they were interchangeable it would be listed as the same part number. no reason to make multiple numbers for the same part. so no they are not the same.
yellow_submarine
Feb 5, 2024 07:20 PM
bigred'sB5
Apr 7, 2012 04:43 PM
bigred'sB5
Apr 5, 2012 01:09 PM
Audi654
Sep 4, 2011 10:36 AM
Prizmatik
Apr 1, 2009 12:12 PM
