Stock idle vacuum question
Old Apr 29, 2011 | 12:26 PM
swm5126's Avatar
Default Stock idle vacuum question
I recently installed a boost gauge in my 1.8T. From what I understand, the vacuum should be somewhere around -20 when the car is idling. Mine seems to sit at about -11, when idling and even when cruising.
Does this indicate a a vacuum leak somewhere? I do seem to get close to the stock 7-8 psi when I'm WOT in 4-5 gear, but the fact that my idle seems low has me wondering...
Old Apr 29, 2011 | 02:20 PM
CCA4's Avatar
Yeah 11 in. hg. is low at idle. Mine idles around 24 and when coasting in gear it sits at about 28 in hg. You might want to take a look at replacing some/all of your vac lines.
Old May 1, 2011 | 11:59 AM
swm5126's Avatar
Yeah that seemed to be the issue. I was replacing my DV valve anyways so I went ahead and replaced all the small braided vac lines. After putting everything back together it holds at about -22 when idling and -25/-26 when cruising. Granted, I'm not sure how accurate a mechanical gauge is but does this seem better? Or I may still have a small leak somewhere?
Old May 1, 2011 | 12:39 PM
MetalMan's Avatar
Your idle is sitting right where you want it, good work.
kidhanny
Mar 27, 2012 07:42 PM
a4intec
Mar 18, 2011 11:22 AM
theother1wstolen
Aug 21, 2009 07:26 AM
neoneddy
Aug 3, 2009 09:06 PM
kextyn
Apr 3, 2006 04:23 PM
