stock injectors flowrate?
Hey guys, I'm trying to figure out what flow I need for the water/meth group buy, and I'm wondering if anybody knows the cc of the stock injectors?
Also I'm going to get larger injectors with my turbo upgrade, so is it worth it to get two sets of nozzles for the flow, or should I stick with the ones made for the injectors I'm going to use with the turbo? I don't want to kill my tip tranny with w/m + a K03... think I'll be fine? [&:]
no they are 3 bar if stock. It would be good to buy an adjustable fpr and turn it up to about 55psi+
right now our injectors flow 26.9 lb/hr@43.5 psi
with a 4 bar fpr you will be at 31 lb/hr @58 psi
at 65 psi fpr your flowing 33 lb/hr
You cheat the stock injectors or any injectors pounds per hour flow ratewith fuel pressure increase. For more hp applications it is always a rule to up the fuel supply for the demand. It would be a good idea when upgrading injectors, to get a bigger fuel rail to supply the fuel demand. I think that we can run these cars at 60 psi preatty eaisily but, a bigger fuel rail would be recommended.
xxipsxx
Dec 11, 2010 03:13 PM
A4TUNEIT
Apr 9, 2007 02:56 AM
Good thing for upgrades
