Strut Mount install
Old Aug 20, 2010 | 03:54 PM
Nevalite's Avatar
Default Strut Mount install
Hey guys,
So I need to replace my upper strut mount and I just needed clarification before ordering the part. I'm guessing I'll have to disconnect all my CAs and knuckle and remove the strut... Do I need spring compressors to compress the spring and take it off that mounting plate at the top? Is the strut mount in there?
Thanks
Old Aug 20, 2010 | 04:04 PM
onepoint8tee's Avatar
You'll need a spring compressor to get the top plate off. Strut mounts are rarely an issue. You sure it needs replaced?
Old Aug 20, 2010 | 04:22 PM
Nevalite's Avatar
Yeah well I've changed all the CAs, TE and end link and there is still a rattling coming from up there so I'm pretty sure its the strut mount. The part is only like 10$ so if it isn't the issue it's not the end of the world.
Old Aug 20, 2010 | 04:47 PM
Audacity's Avatar
you should check your inner brake pad. mine is loose and it sounds like the car is falling apart..
Old Aug 20, 2010 | 05:07 PM
ImTheDevil's Avatar
Definitely check that inner pad - it's been the culprit for several people.
Old Aug 20, 2010 | 06:02 PM
I had the pad/ caliper retaining clip on the outside pop out and it produced a horrible rattle. I was very surprised... Car drove and stopped fine. The strut mount would be more likely to squeek or thud rather than rattle if it was bad.
Old Aug 20, 2010 | 06:04 PM
Audacity's Avatar
yeah my retaining clip somehow broke. but the pad was like brand new. no way am i replacing them yet. haha.
Old Aug 20, 2010 | 08:34 PM
Nevalite's Avatar
I'm changing my brakes next week so I'll check that out, thanks guys.
Old Aug 20, 2010 | 08:40 PM
If it may be the retaining clip or brake related, I would not put it off. Takes about 2.5 minutes to jack up the car take the wheel off to have a look.
ECS Tuning
Oct 14, 2013 03:39 PM
ECS Tuning
Oct 14, 2013 03:38 PM
kybowmans
Apr 1, 2012 09:05 PM
milo55041
Oct 24, 2007 02:42 PM
haveaseat
Jun 14, 2006 01:02 AM
