Stuck outer tie rod end
Old Jul 19, 2012 | 05:05 PM
Sheasta's Avatar
Default Stuck outer tie rod end
Need this done to pass inspection. Have already backed off jam/ adjustment nut as you can see here : Name:  72d840a3.jpg
Size:  85.9 KB but the outer wont break free from the inner threadwise. I just started spraying lots of pb blaster. Any other tips?
Old Jul 19, 2012 | 09:24 PM
Sheasta's Avatar
Still stuck... Used a shitlosd of pb blaster. Gonna let it sit overnight and try. After have been told to try freeze off and I dont have or know anyone who has acedylene torch. Other ideas or tips?
Old Jul 19, 2012 | 09:56 PM
CCA4's Avatar
Torch, PB Blaster, and violence are your only options here. You might also try Kroil or Deep Creep, both are very good penetrating oils. I dunno if this is still an option, but you should always use a legit box wrench wherever possible instead of vice grips or a crescent wrench. Worst case scenario you're going to have to disconnect the TRE from the rest of the suspension and use some big *** channel locks to turn it completely out of the rack.
Old Jul 19, 2012 | 10:45 PM
jonbonesjones's Avatar
Moderator
MAPP torch, best 50 bucks i have ever spent.
Your also using the wrong wrench, never do this again
Old Jul 19, 2012 | 10:58 PM
redline380's Avatar
Legal Moderator
torch it. a propane torch will help but acetylene is best. or you could see if the inner tie rod unscrews and just take the whole assembly out
Old Jul 20, 2012 | 03:04 AM
villacorta32's Avatar
U might as well replace both, I had the same issue and I had to remove both inner and outer. I rented the tie rod end removal tool from autozone, I beloved it is the gm tool, but I had to get a 32 mm socket to attach to that and I used enough extensions to be outside the wheel well. Make sure u turn ur steering wheel the complete opposite way of the side u are working on, this makes it come out and gives u more room to work, good luck!
Old Jul 20, 2012 | 07:36 AM
NorthD's Avatar
"U might as well replace both, I had the same issue and I had to remove both inner and outer"
Same thing easier just to do this..... X 2
Old Jul 20, 2012 | 11:10 AM
Sheasta's Avatar
I thought you need to remove the outer to attach the tool that removes the inner?
Old Jul 20, 2012 | 11:34 AM
Sheasta's Avatar
Size:  253.3 KB applied pb blaster about 15 times in about 8 hours then let it sit overnight. I didnt have much faith in this working but it did. Thanks everyone.
Old Jul 20, 2012 | 12:14 PM
vgo's Avatar
vgo
Glad you got it out... I'm doing my control arms next week. I'll blast everything in there with PB blaster and drive around for the week before tackling the job.
