Sudden cyl 2,4 misfiring under load
Old Jun 13, 2010 | 02:44 AM
CornerHard's Avatar
Default Sudden cyl 2,4 misfiring under load
I have a 2001 A4 1.8T Avant. The previous owner claims to have replaced the coil packs.
I was driving home from work, and about halfway along my freeway journey, the car started bucking under any load, with the CEL was flashing. It would drive fine if I was maintaining speed or slightly slowing down, but any load would cause it to misfire. It was actually hard to keep the car at 60mph, but I limped it home in the slow lane. I scanned it with VAG COM when I got home and retrieved:
P0300
P0302
P0304
It seems a bit weird that two coil packs would go back at the same time. Maybe a hose is disconnected? What are some other things I can check besides spark plugs and coil packs? I tried driving the car around the block, and it will misfire in first gear at 5mph if I give it more than the smallest bit of throttle.
Thanks for any ideas
Old Jun 13, 2010 | 05:23 AM
A4 2000's Avatar
Wow that sounds really sensitive. For now, put some new plugs in and gap them to .028 and see what happens. You also can't trust everyone these days when they say they've replaced something.
Old Jun 13, 2010 | 05:27 AM
bradtyler02's Avatar
Easy check on the coil packs, switch 2 and 4 to 1 and 3, reset the CEL, drive, misfire, scan for codes. If they switched to cyl 1 and 3, you know it's the coil packs.
Change the plugs, too. They're not too expensive and these little 1.8T's eat them like candy.
Old Jun 20, 2010 | 04:21 AM
CornerHard's Avatar
It looks like it was indeed the coil packs. The previous owner only replaced one of the four, and two of the old ones were causing the issues. Thanks for the tips!
Old Jun 20, 2010 | 04:47 PM
A4 2000's Avatar
Cool. I bet you're happy now. I sure was when I figured out why my car was misfiring.
normal
Jan 21, 2015 02:14 AM
erubus
Apr 19, 2012 11:18 AM
Miss Molly
Oct 31, 2008 11:48 PM
vision
Apr 11, 2008 02:27 AM
BostonB5S4
Aug 29, 2006 03:32 PM
