tail light and break light out
Old Nov 9, 2008 | 08:32 AM
skrullskrull's Avatar
Default tail light and break light out
Hey,
My left tail light and break light are out and I'm pretty sure it isn't the bulb. I tried replacing the bulb a couple times and it's still not working. I was wondering if anyone has had this problem before, or anyone could lead me in the right direction as far as what it could be. Thanks in advance!
Old Nov 9, 2008 | 08:54 AM
ImTheDevil's Avatar
Try taking the bulb out, turning it 180 degrees, and reinstalling it. The height of the side pegs on the bulb base, relative to the bottom, is different but close so it's possible to install the bulb "wrong". I had that problem when I first got my car. Try that and see if it helps - basically put it back into the bulb tree so that the peg A goes into the slot of the bulb socket where peg B was when you removed the bulb. It may do nothing for you, but in my case it fixed the nonfunctional brake bulb that was driving me crazy for a week or so.
Old Nov 9, 2008 | 09:54 AM
Ketamine1's Avatar
Whats a break light? Make sure your wiring harness is snug and no wires are severed,stripped, or rotted looking.
Old Nov 9, 2008 | 04:21 PM
CCA4's Avatar
Fuses? Maybe he should have called it a broke light (hehehe)
Old Nov 9, 2008 | 07:49 PM
that joke was terrible, but thanks for all the help guys, i'm going to try all of your suggestions!
Old Nov 9, 2008 | 09:54 PM
CCA4's Avatar
lol i know but i couldn't resist. Did you have any luck so far?
Old Nov 10, 2008 | 04:31 AM
hahah i haven't tried yet cause im in college and have been studying none stop for three tests today.. but im going to try after i'll let you guys know.
Old Nov 10, 2008 | 08:19 AM
CCA4's Avatar
I thought of somethin last night but was too lazy to get out of bed to post. In my bronco, i changed the brake lights and didn't use any dielectric grease (kinda looks like peanut butter) and within a couple months they had corroded and crapped out. Maybe check to make sure the bulbs/connectors aren't corroded?
Old Nov 10, 2008 | 01:00 PM
akielb's Avatar
If it's the fuse then your park lamp/turn signal(not sure if the turn will work) will also not work on that side. They are both under the same fuse.
Mischief
Oct 11, 2010 01:41 PM
ArmenB
Oct 11, 2008 12:23 PM
tsk
Apr 27, 2008 04:56 PM
TweeJr
Jan 3, 2006 04:26 AM
