test pipe problem
Old Apr 26, 2010 | 09:47 AM
trbosqrl's Avatar
Default test pipe problem
i just installed my test pipe and every thing is fine for the first day.today i started my car and as i was driving the retard lite came on, i pulled over and hade the code read it was o2 bank after the cat i erased the code and it came back again is there a fix for this because i was reading in diy and it doesnt explain how to bypass it
Old Apr 26, 2010 | 10:01 AM
dragonrage's Avatar
The fix is to use a catalytic converter.
Old Apr 26, 2010 | 11:27 AM
FASTER's Avatar
Tech Slut
I agree with dragon, even I have a race cat in my downpipe. But you can get away with anti-foulers. They jus space the o2 out of the tp a lil. Unplug the wire completely when taking it out or putting it in so you don't twist the wire up.
Old Apr 26, 2010 | 11:55 AM
dragonrage's Avatar
anti-foulers = YMMV. The "anti-foulers," unfortunately, do not take the foul odor away from an exhaust running without a cat.
Old Apr 26, 2010 | 12:08 PM
Audacity's Avatar
theres a garage down the street from me. he was telling me how theres like a little module that you splice into the o2 sensor wires between the sensor and the connection somewhere that runs off a 9 volt battery and it fools the car into seeing the right amount of voltage change. you could look into that. i don't know what you would call it.
Old Apr 26, 2010 | 06:15 PM
joenelson7687's Avatar
Or you could just spend a few bucks and get the anti-foulers...They are like under 10 bucks
Old Apr 26, 2010 | 10:27 PM
jjcrt2's Avatar
if you ever get chipped they have a program for test pipes...
powersmokin
Apr 10, 2008 10:49 AM
The Bishop
Nov 30, 2006 06:03 PM
Hanestyle
Oct 24, 2006 04:07 AM
Mythstery
Jan 19, 2006 08:17 PM
greenday
Nov 29, 2005 03:43 PM
