is there anything friggen cheaper?
all i can find for my 30v v6 (1998 quattro) is friggen 100 bucks for plug wires and id have to wait for shipping. its retarded any help on prices and stores would be great.
https://www.audiforums.com/forum/diy-do-yourself-55/how-make-your-own-performance-plug-wires-flyboy-15632/
then whatever plugs you want to get.
those don't look like yours because they are modded. the ends are the same and that's what matters. if you take yours out you'll see the end that goes into the spark plugs look a lot like the ones in the picture. why do you need wires? they hardly ever go bad
before spending 100 bux on wires, try to isolate the misfire and switch wires with a different one and see if it follows. if it does, your wire is bad. if it doesn't either your plugs are bad or ignition coils are bad. another thing that can cause random misfires on a 2.8 is a bad ECT but it's only like 6 bux at autozone.
Electronic Coolant Temperature sensor...and it's more like $25 on ecstuning.com. I have to replace mine next week because it was causing ignition misfires and my CEL is on for a bad ECT
