Thermostat going out?
Old Feb 18, 2010 | 12:39 AM
rplets15's Avatar
Default Thermostat going out?
Hey guys, so my car never warms up to past the first line and its the same deal with my oil temperature. I was thinking this is due to my thermostat being stuck open or just completely gone out. Is that right or no?
Old Feb 18, 2010 | 12:57 AM
evan671's Avatar
Member
I have the same problem, change out your thermostat. Im doing mine next weekend.
Old Feb 18, 2010 | 01:39 AM
2fast4u66's Avatar
Same deal here, lol. I got one on order
Old Feb 18, 2010 | 11:54 PM
rplets15's Avatar
OK sweet I think Ill order one now, btw how much coolant do you think I should get?
Old Feb 19, 2010 | 12:18 AM
auditech79's Avatar
Should only need half a gallon of G12 mixed with half a gallon of water.
Old Feb 19, 2010 | 06:12 AM
fromzerophreak's Avatar
I just got my thermostat changed yesterday and mine was doing the same thing except it wouldn't warm up at all if I drove it. It warmed up one notch away from center when sitting still. All good now tho, I put a piece of card board in the slot by my radiator and that helped warm it a little bit
Old Feb 19, 2010 | 12:42 PM
leighsean's Avatar
mines doing the same thing..you guys post back here if it solves your problem, hopefully this will fix mine too.
Old Feb 24, 2010 | 06:37 PM
evan671's Avatar
Member
I just changed mine today, took about an hour. Here is a pic of after I installed it. Before the temperature needle would never get past the first line now it stays at the middle. Also, the oil temperature gauge is functioning now.
Old Feb 25, 2010 | 11:02 AM
exequiel3k's Avatar
Did you do it yourself?
I read some DIY's on thermostat but they all seem to refer to a TB change..
Is there a way to just change the thermostat without having to go through all the mess of partially taking the front off.. OR, sorry for my ignorance..
Old Feb 25, 2010 | 02:00 PM
evan671's Avatar
Member
I did do it myself. It took about an hour to do. I didn't come anywhere close to messing with the timing belt. First I removed the throttle body, next I removed the intake manifold brace, and unbolt the thermostat housing. Its really easy.
