Tire Size Question
Old Aug 15, 2013 | 02:09 PM
HulkB5's Avatar
Default Tire Size Question
I found a set of wheels on craigslist for a winter setup.
The wheels are 18x8 with a 35 offset.
The Tires on them are 2x 245/40/18
AND 2x 265/35/18
Blizzaks
I need to know if these would affect the quattro or not?
Old Aug 16, 2013 | 08:25 AM
HulkB5's Avatar
If you calculate the difference its a 1.6% change in diameter.
I believe Quattro has as much as a 3% tolerance for diameter?
But it would be nice to hear from someone more educated on wheels.
Old Aug 16, 2013 | 01:35 PM
Kamil`'s Avatar
I believe that the B5 models support a 57.1mm offset by default. Keep that in consideration. Since those are big wheels, make sure you have enough clearance for bumps on the road.
Some a**holes put huge wheels on a car that has been lowered too far. Then it looks stupid and performs like a Ford Model T
Old Aug 17, 2013 | 12:01 PM
HulkB5's Avatar
I believe the center bore is 57.1
The stock offset I think is somewhere around 35.
And this is for a winter setup and I need 18"+ wheels to clear my A8 brakes
Old Aug 17, 2013 | 09:40 PM
Kamil`'s Avatar
Oh your right.
If your getting winter tires, look into the company Nokian. Hands down best winter tires on the planet.
redline380's Avatar
Legal Moderator
both sets of my wheels are 45 offset, so those might be a tide wide, especially the 265's. unless you got hella rolled fenders, I think its a no go
Old Aug 19, 2013 | 10:11 AM
McGovs2.7TB5's Avatar
Sell the tires on there for some 225/40/18s and you be good to go. The narrower the better when it comes to Winter wheels anyway.
Old Aug 19, 2013 | 10:27 AM
bshusted's Avatar
Stock 16" wheels clear the A8 brakes just fine.
Old Aug 19, 2013 | 01:36 PM
Kamil`'s Avatar
15" and 16" audi OEM wheel pics 5x112 bolt pattern
that link right above has most of wheels that came stock on a few Audis from like 96-02 I believe. it helped me out a bit.
foxracing4500
Apr 29, 2011 03:45 PM
BlackSpyder
Nov 12, 2007 10:55 AM
acetrebo
Sep 21, 2007 01:19 PM
joshpsu
Apr 20, 2007 03:51 PM
Doose
Jun 24, 2004 11:33 AM
