tool for fuel filter?
Old Mar 4, 2013 | 10:28 AM
phatjames167's Avatar
Default tool for fuel filter?
I am about to change out my fuel filter and it looks like i need an 8mm 12pt 3/8 drive allen to remove a strap that holds the filter. I've checked at home depot an advance auto but it looks like no one carry's 12 points. does anyone know if this is something that could be found locally or is it something that has to be ordered online? if so does anyone know where i might be able to get it from?
Old Mar 5, 2013 | 07:16 AM
CCA4's Avatar
I just used an 8mm torx bit, worked ok. And when you put it back together with the new filter, **** that strap. I didn't put mine back on because it was a pain in the ***. That filter isn't going anyplace.
Old Mar 5, 2013 | 07:57 AM
mtroxel's Avatar
I think it's a tripple square. I had the tool, but like most of us, mine was rusted in place. Special tool I needed was a hack saw blade handle.
Originally Posted by CCA4
**** that strap.
Well said. I ended up putting a zip tie on there, just because. But I'm not sure how necessary it was.
Old Mar 5, 2013 | 11:48 AM
BaseDrifter's Avatar
Site Moderator/B5 Tech Guru
It is a triple square.
I chose the method of using a pair of channel locks.
Old Mar 5, 2013 | 11:57 AM
I put the rear up on ramps last night and went along with this DIY: AudiWorld Tech Articles and only had 1 strap and then when i tried moving the tank down it didn't budge at all and didnt see the filter at all. is the 01 a4 fuel filter location different from the 99? this was the only instructions i found online.
Old Mar 5, 2013 | 01:05 PM
hartsoe1's Avatar
you go at it by crawling under the passenger side rear door, right in front of the passenger rear wheel. Look straight up. cut the darn plastic strap or pry bar it until you can stretch it enough to pull the old one out. watch for gasoline spray to the face when you break the first banjo bolt.
Old Mar 5, 2013 | 02:09 PM
CCA4's Avatar
Good advice. I took off my gas cap, pulled the fuel pump fuse and ran the car out of gas before I did mine, and STILL got sprayed with gas when I loosened the banjo bolts. Watch out for your eyes and ****!
Old Mar 5, 2013 | 02:48 PM
so do you remove the tank at all or lower it some as the diy says?
Old Mar 5, 2013 | 04:02 PM
mtroxel's Avatar
I didn't remove mine, but I lowered it just like that DIY says. I'm not sure why yours didn't come down. I do remember having to pry on it a bit. I think you're actually bending the platic tank around the diff if I recall right.
Old Mar 5, 2013 | 08:54 PM
hartsoe1's Avatar
I replaced it today. On ramps under the rear end. I started loosening the tank straps, and thought one was spinning, plus I wondered how it was going to be to get it back in place, so I just used a flat screwdriver to loosen the plastic band around the filter (it never broke, as I was hoping) and pulled it out by the bolt with pliers protected with cloth. I had bought a filter and 4 washers from the dealer ($44 dollars). There are two silver ones and two red ones (aluminum and copper?). The alum ones went on the 19 mm bolt and the copper ones went on the 17 mm bolt - you can't screw this up because they are different diameters. I greased her up, pushed it in half way (there is a lip on the plastic holder at the bottom), drove around a while, and found no leaks. then with wood block and rubber mallet, I pushed it further into place. It ain't going nowhere.
see above, carefull dropping the fuel tank on old cars with rusted nuts and bolts. this will be your one and only filter change, so make it easy on yourself and rig it.
