Transmission Fluid Change
TRY WWW.BLAUPARTS.COM they have and show anything you will want to know as for the fluid you can use royal purple max atf or mobil one atf both of these are G-052-025-A2 AND ARE COMPATABLE WITH THE VEHICLE YOU HAVE. you will pay half the cost for these fluids as compared to audi...... JUST A HINT...BUY A COUPLE MORE QUARTS THAN YOU THINK YOU NEED
BUMP! I dont have the 350$ vag and i need to do a tranny flush. Should i just run it hot to get as much out as possible to drain. Then let it cool and fill it until it comes out, then runt he gears, fill, run the gears, fill again? HELP!
I believe it's some absurdly large 12-point safety bit. ECS should have them. I need to drain/flush/fill my gear oil as well..
