Trouble Starting but No Codes
Old Apr 15, 2010 | 04:42 PM
rawdney88's Avatar
Default Trouble Starting but No Codes
Recently did a 60k mile service. SPark plugs replaced with proper gap. the car (On occasion) will kick when i try and start it, but it won't turn. ill try a second time and it will kick but not turn. BUT, if i give it a little gas it starts with no problem.
this happens once and a while. probably 2-3 times a week when using it daily. other than that, the car usually starts with no problem. we did a code check and nothing came up. cleared the codes and check again and still nothing.
any ideas?
Edit: Turn=Start
Old Apr 15, 2010 | 05:29 PM
Dallas09's Avatar
Coolant temp sensor is my bet... It doesnt always throw a code when its going bad... If it thinks your coolant is a different temperature than it actually is it will dump too much or too little gas.. You can try cleaning the contacts at the connector for a start, but it would be a good idea to just replace it.
Old May 26, 2010 | 03:11 AM
rawdney88's Avatar
replaced it, still won't start unless i press on the gas. doesn't happen always but it is noticable when it does. happens when i least expect it. i am running an old battery? maybe that's it? i
EDIT: it ran the code for the coolant temp sensor, and i replaced it but no change.
Old May 26, 2010 | 11:39 AM
joenelson7687's Avatar
have you tried a throttle body allignment?
Old May 26, 2010 | 03:40 PM
rawdney88's Avatar
hey, how much you think this would cost? should i just ask my mechanic to do it?
Old Jun 16, 2010 | 02:20 PM
2.7twin's Avatar
a bad coolant temp sensor and the no start when cold is almost a universal problem among all computer controlled engines but remember there are almost always two sensors. your looking for the one that goes to the ecu. it will make the engine run lean or rich and can ruin the plugs if let go to long. once you foul ngk's even once, throw them out.
Old Jun 16, 2010 | 05:59 PM
rawdney88's Avatar
i already replaced the coolant temp sensor. if there are two...im not sure which one i replaced then. im pretty sure the one that was replaced sits by the MAF kinda in front of the battery
Graftly1
Aug 20, 2010 10:17 AM
AutoUnionFan
Nov 17, 2008 01:26 PM
munster79
May 18, 2008 06:23 PM
Howard Mawditt
Apr 27, 2007 06:27 AM
careycj0219
Oct 31, 2006 09:33 AM
