it is true
Old Feb 4, 2010 | 05:49 AM
ImTheDevil's Avatar
I don't have a clue what one retails for - check it out online from a vendor or two.
Old Feb 4, 2010 | 07:56 AM
CCA4's Avatar
Originally Posted by corwin06
how much would it cost
plain old code readers can be had online for less than $100. Any OBDII code reader will do the trick. However, if you've got a lap top you can download the free version of Ross-Tech's VAG-COM and pick up an appropriate cable online for MUCH less than $100. Just do some research and see what you can find.
Old Feb 4, 2010 | 02:15 PM
corwin06's Avatar
Member
alright thanks. i just hope its not gonna cost a lot so i can keep it otherwise i gotta sell it or something
Old Feb 4, 2010 | 02:21 PM
Andrew149's Avatar
if you want vagcom you can do it for $25 on ebay but your gonna haft to ask one of us for what one to buy before you do it
Old Feb 4, 2010 | 03:09 PM
mikekey's Avatar
Mine works fine and I'm not throwing massive amounts of money at it.
Old Feb 4, 2010 | 07:05 PM
Andrew149's Avatar
your what?
Old Feb 9, 2010 | 01:25 PM
corwin06's Avatar
Member
could your computer or camshaft censor make your car burn more oil
Old Feb 10, 2010 | 12:20 PM
  #18
corwin06's Avatar
Member
anyone?
Old Feb 10, 2010 | 12:30 PM
  #19
dragonrage's Avatar
I don't think so. That's some sort of seal or gasket.
Old Feb 10, 2010 | 09:37 PM
  #20
kayakman13's Avatar
Computer would have no say in oil consumption. It simply manages input from sensors and adjusts Air/Fuel ratios. Cam sensor just monitors cam position I think.
Things that would:
A leak. Get out cardboard under the car overnight.
Bad piston rings (oil sneaks up from the sump and past piston rings into the cylinder, where it burns. telltale sign would be whiteish smoke from exhaust)
Bad turbo. (More oil burning. Disconnect the turbo to hardpipe hose. Under the car, connected to the core support. The hard pipe runs from turbo to intercooler. If you find a lot of oil in there, its bad news.
Other than that, its just leaks. Our cars burn oil i've been told in the city. Get it on the highway for awhile and it wont burn any for another thousand miles. They're just made for the Autobahn.
