it is true
Old Feb 11, 2010 | 09:50 AM
  #21
corwin06's Avatar
Member
i dont have the 1.8T so a bad turbo and intercooler are out. When i brought it to get the codes i checked the oil and it was 2 quarts low and i was 1,000 miles away from an oil change. how would you know if you had a bad gasket
Old Feb 12, 2010 | 10:48 AM
  #22
jjcrt2's Avatar
you would know if the head gasket was shot if you had coolant in the oil, an *** load of white and blue smoke out the exhaust and also if your coolant over flow tank was bubbling up
Old Feb 12, 2010 | 04:11 PM
  #23
corwin06's Avatar
Member
cant say my car has any of those symptoms which is why i am confused
Old Feb 12, 2010 | 04:29 PM
  #24
dragonrage's Avatar
I don't think he has a bad head gasket but this is also bad and incorrect advice. Head gaskets can break in many different places and can have various consequences, only some of which you listed, but a car with a blown head gasket can have any combination of the problems. It's actually unlikely to have all of them.
Old Feb 13, 2010 | 09:59 AM
  #25
jjcrt2's Avatar
no **** i didnt say it would have all off them i just gave him some of the symptoms so how is that bad advice i was just giving my input in what ive delt with for years instead of down talking my advice why dont you put your in put in? and actully its not uncommon to have most of those issues if you blow a head gasket seeing that ive seen it a million times working in a tractor trailer shop granted he dosnt have a 12.7 l cummins some of these signs may be true so like i said im not trying to be a dick but before you bad mouths someones advice take into consideration that i was just trying to give someone an idea based on my expericance
Old Feb 13, 2010 | 10:59 AM
  #26
dragonrage's Avatar
It's common to see a blown head gasket only leaking oil to the exterior, or only mixing the coolant and the oil, or only burning oil or only burning coolant, etc. What you said sounded like you were saying he needed to have all of the symptoms.
Old Feb 16, 2010 | 05:59 PM
  #27
corwin06's Avatar
Member
the PCM processor is that the main copmuter ECU?
chaos92287
Jan 31, 2007 04:52 AM
norcatalyst126
Aug 17, 2006 04:28 PM
nexusgroove
Aug 7, 2006 03:24 AM
