Trying to get my VCDS-Lite to work.
Old Jan 9, 2011 | 06:04 PM
pbbg's Avatar
Default Trying to get my VCDS-Lite to work.
Okay I can't get this program to work. I purchased this OBDII cable from ECS.
http://www.ecstuning.com/Search/VT1A0003/ES6928/
I downloaded driver software from this site and version 2.08.08.
http://www.ftdichip.com/Drivers/VCP.htm
I then downloaded VCDS-Lite release 1.1 which is at the bottom of this webpage.
http://www.ross-tech.com/vcds-lite/download/index.html
I extraced the files from the folder for the driver and installed and my computer recognized that it was a serial to USB converter.
When I run a auto scan it keeps running and opening new ports. So I closed the scanning and did the OBDII check and it gives me this error.
Car is NOT ISO/OBD-II Compatible! IF this car is a VW/Audi/Seat/Skoda Try SELECT > Individual Controllers.
I can't find this Individual Controllers option.
Anyone familar getting this program running because I am lost.
Old Jan 9, 2011 | 07:32 PM
dragonrage's Avatar
First of all, what Windows version?
Old Jan 9, 2011 | 09:10 PM
Mad Cow's Avatar
With that cable you'll need to find vagcom 409.1. Does it at least test properly in the options menu? With these cheap cables it's not plug and play, you gotta play with port settings and stuff.
Old Jan 9, 2011 | 09:25 PM
pbbg's Avatar
vista
Old Jan 9, 2011 | 09:28 PM
pbbg's Avatar
what do you mean test properly? I was able to find the correct COM port and it acted like it was able to read the cable in that COM port. When I go to test it keeps searching for something and will got to a different number of a port or terminal or something.
Old Jan 10, 2011 | 06:48 AM
02A6Beau's Avatar
There should be an option to choose USB in the options menu.
at least there is on mine but I have the full version
Old Jan 10, 2011 | 10:10 AM
pbbg's Avatar
no i dont have that option
Old Jan 10, 2011 | 10:31 AM
pbbg's Avatar
i thought there was a software avaiable from Ross-Tech that is free. If I am wrong on that chance are that is why it isn't working.
Old Jan 10, 2011 | 06:49 PM
pbbg's Avatar
does anyone have any clue? I really need to pull codes off my car because it is not running good at all.
Old Jan 10, 2011 | 06:54 PM
dragonrage's Avatar
32-bit or 64-bit Vista? Have you checked the device properties for the USB-serial converter device?
