Trying to get some answer for my A4...
Old Sep 9, 2010 | 11:51 AM
qunair's Avatar
Default Trying to get some answer for my A4...
Okay so three days ago ive went and brought a 96 laser red Audi a4 2.8 Q. okay im pretty decent when it comes to working on cars. i just need to get point in the right direction before i go and spend lots of money. My first issue the 1n1 code is coming on. thats the power steering code ive figured that much out, and i was leaking power steering fluid but now im not and my call still has a lil whining noise. so what to do? (ikr) second issue my rear driver pass window wont go down but the switch still lights up on the door and when i press the master control switch on the driver door it turns the light off and on.
so what do i do to get it to work? and im missing my driver key lock for the driver door where can i find that at? also can someone tell me if i have a sport package suspinsion or not....and is the all blk grill with out the audi rings common for my model? cus i have no rings on the front of mine any help would be apprecaited or even a phone number to pick some of you guys heads to get my audi in order .....thanks in advance
Old Sep 9, 2010 | 11:55 AM
Tourbo24's Avatar
hey i was just wondering what did you do to stop the power steering leak?
Old Sep 9, 2010 | 12:19 PM
CCA4's Avatar
When the driver operates any of the windows, the switch on that door is disabled so the annoying kid who's sitting there can't keep the driver from rolling the window up . If you still have good power to the switch but the window isn't moving, my guess would be the window motor. Take the door apart and test the motor.
The sport package comes with beefier sway bars, red bilstein sport dampers and stiffer springs. There's a noticeable difference in ride height between that and the non-stock suspension. First look at the shocks, if you can't tell, take a picture and post it up, we should be able to identify it for you.
The grille you described isn't OEM. All OEM grilles, sport suspension or otherwise, facelift and pre-facelift, all have rings and chrome trim.
It will be good for you and the rest of us to set up your signature in the User CP. Include any relevant info about your car: year, engine, mods, a picture.
EDIT: Btw, welcome to AF . Read the f.a.q. sticky at the top of the page, its got a crap load of excellent info in it.
Old Sep 10, 2010 | 12:26 AM
qunair's Avatar
thanks guys, and on the power steering leak it leaks when it wants to. side note the strut/spring i changed that out today.
Old Sep 10, 2010 | 12:38 AM
Andrew149's Avatar
pics!
Dozanti
Jul 30, 2011 03:26 PM
carbonhornet
Sep 25, 2010 01:42 PM
Coors
Oct 22, 2008 10:48 PM
DakotaEpic
Apr 23, 2008 06:22 AM
kickasS4
Oct 13, 2006 10:47 PM
