Turbo Replacement Help Needed
Old Feb 25, 2010 | 09:04 AM
dragonrage's Avatar
The way you install/remove studs is to put two nuts on there and jam them together. You then use a wrench on the inner nut to remove the stud or the outer nut to screw it in. If you can't do it that way, you're basically going to have to drill it out. Edit to add: Do try Kroil (or PB Blaster), too, and you can try a torch though a torch can make it brittle and make it thus snap easier.
But... just buy a new turbo, man. Sounds like yours is probably too far gone to fix. Send it to G-Popshop and see. If they can rebuild it, have them do so. If not, either buy their K03/K04 hybrid or do an upgrade to a GTxxRS turbo.
Old Feb 25, 2010 | 09:07 AM
hiwords's Avatar
did you try putting 2 nuts on the stud, lock them to each other and then turning the bottom one to get the stud off?
dammit dragon you beat me to it
disclaimer: that sounds really sexual, no homo
Old Feb 25, 2010 | 02:16 PM
FASTER's Avatar
Tech Slut
Hes got a new k04, hence the problem of it not coming with the studs. But def try some penetrant, i like "deepcreep". Then do the two nut thing, it should get them out, but again they might break. You will probably end up just buying new ones.
Old Feb 25, 2010 | 02:34 PM
Desert Fox's Avatar
Wow, I never though about the two nut thing. Thanks for the idea.
I think what im gonna do is try to get new ones so I have new ones today and if I cant, ill try getting the old ones out.
Old Feb 25, 2010 | 03:36 PM
dragonrage's Avatar
If you want to buy some new ones and don't want to wait, I'd go down to Fastenal and get some grade 10.9 ones.
Old Feb 25, 2010 | 04:58 PM
Desert Fox's Avatar
I have no Idea what that is. However carquest said they could match them up, and the dealer wont have them in till sat. So I guess im bringing both my turbos in to get em checked for sizes.
Old Feb 25, 2010 | 06:24 PM
dragonrage's Avatar
They're like an Ace Hardware that doesn't suck. www.fastenal.com
They're generally only open M-F 8/9-5, though.
Old Feb 25, 2010 | 11:35 PM
  #18
BaconBait's Avatar
You're not that far from 034 motorsport. You may want to check out a few local VW/Audi tuning shops. They always have stuff like that sitting around.
Old Feb 26, 2010 | 06:58 AM
  #19
Desert Fox's Avatar
After going all over the place today, suprisingly autozone had them. And got it all back together in a few hours, with some time to spare for breaking the turbo in before a little drive.
Thanks for all the help guys, ill throw some pictures up of the install and after.
jajayao
B8 Models
Jul 22, 2016 07:15 AM
Jérémy Rometti Hartman
Nov 20, 2011 12:58 PM
greene08
Nov 19, 2007 10:16 PM
kraylon
Jul 11, 2007 06:09 AM
kchao2000
Apr 11, 2005 08:34 PM
