AudiForums.com
-   B5 Models (https://www.audiforums.com/forum/b5-models-69/)
-   -   turbo touble! (https://www.audiforums.com/forum/b5-models-69/turbo-touble-154021/)
halfpint Jul 26, 2010 07:06 PM
turbo touble!
Hey guys i have a 1997 A4 1.8t with 83k miles i got the giac chip from awe tuning didnt have problems with the turbo until i put a carbonio cold air intake. it use to work on and off and found out the D/V was sticking so got a new one, and worked for a bit. Now it works but does not have as much pool any ideas?
onepoint8tee Jul 26, 2010 07:12 PM
Pull? Did you install the MAF in the right direction? Double check all the connections electrical (maf, n75, etc.) and hoses that were disconnected for the install.
halfpint Jul 26, 2010 07:16 PM
yeah everything is hooked up right and i dropped a new n75 in and nothing still
BaseDrifter Jul 26, 2010 07:42 PM
Do you have a boost gauge? What is it reading?
halfpint Jul 27, 2010 03:49 PM
no i dont have a boost gauge, but u can tell when it worked it spun the tires at like 3 1/2k rpm now its a turd
The Bishop Jul 27, 2010 10:12 PM
I would replace the entire vac line from the DV to the mani
halfpint Jul 28, 2010 03:25 PM
yeah ill try that but i mean u can hear th DV workin and the turbo spoils a lil but the backs off even when i have the pedal to the floor
