Unitronics rumor
Old Feb 29, 2008 | 11:33 AM
  #31
Jeff's Avatar
Zombie Defense Force
Default RE: Unitronics rumor
w/m/a will raise the oct level of the fuel. so you can run 91 or 93 oct fuel, spary the w/m/a and run a 100oct program. the w/m/a turns on when you reach a preset boost level. so on my evo i have the meth start spraying at 20psi and then it gradually increase the amout sprayed up to 30psi (max boost). i have a progressive unit so it slowly sprays more and more. there are other systems that are on/off (no spray to full spray)
Old Feb 29, 2008 | 12:04 PM
  #32
Quattro_1.8t's Avatar
ORIGINAL: FasterA4ThanUrs
little thread jack here:
ive been talking to the guy from unitronics, i think his name is mike, and they will have a chip out designed to run with 630cc injectors... im going to couple that with a 50 trim t3/t4 instead of going crazy with the gt3582r and boring out the block. I asked him if he could get it done in less than 2 months and he said yes... so when my license comes back ill be able to finally drive a quick car daily.
I'm going with a garrett t3/t4 50 trim so let me know what your setup is and how that works out, I'm def. interested if it runs good.
Old Feb 29, 2008 | 01:32 PM
  #33
chaos92287's Avatar
ORIGINAL: ThePaintballGuy
Is it even worth it on a 99.5? I can't use lemmi on mine so I don't know if it's worth it or not.
Josh
depends on what you consider worth it. you cant manually alter the timing, but it will still raise the octane and cool your IAT's. and you might be able to get giac to give you another race file for use with w/m. but your tip right? i think running a maxed out k04 could hurt the tip tranny, its gona be above 300 ft lbs of tq
Old Feb 29, 2008 | 01:51 PM
  #34
chaos92287's Avatar
ORIGINAL: Leifer
Brian, I'm looking to hold about 18-20psi, not 25! I don't want to take any chances. But with the w/m injection and lemmi tuning, I'm also going to have a bigger inlet hose, a more secure outlet hose, and a high-flow exhaust mani.
I don't want to push it to the point where I need bigger fuel injectors and oil lines; because at that point I'll throw out the K03 and get a bigger turbo. They seem pretty damn good for the price that you pay; do you have to have it constantly injecting, or is it a timing thing, with when your turbo spikes up that high, your w/m injects so your fuel can burn properly?
you shouldn't get an exhaust mani. its gona give 5hp at best on the spike, and your gona have to buy another mani when you go BT. you wont have to buy bigger injectors, maybe a 5 bar fpr but thats it, and you don't need new oil lines, get those when you go BT. and a new TIP isn't gona do much and your gona have to also change that when you go BT. when you get your TIP made for BT, the same place can do a custom outlet as well.
you seem to want to put money into your current setup, but if your going BT your just wasting your money. you should just put money into parts that are gona transfer over to your BT setup. and then put the rest of the money towards the BT setup.
Old Feb 29, 2008 | 01:57 PM
  #35
techbod's Avatar
well 15 degreesadvance is the optimum for performance cars for short bursts like the 1/4 mile but not sure you can adapt standard cars without the proper tool and VAG wont do it
Old Feb 29, 2008 | 02:00 PM
  #36
chaos92287's Avatar
yeah, if you have a 00+ car you can use a program from revo call lemmingwinks and adjust a bunch of stuff like timing through a vag cable. i just wish us AEB guys could do the same[&o]
CAB509
Jan 24, 2024 07:01 AM
jthessin
Sep 18, 2014 08:04 AM
TGPorsche96
Mar 21, 2006 01:35 AM
moreboost4me
Sep 9, 2005 03:10 AM
