Unknown misfire source Please Help!
Old Jun 27, 2013 | 02:58 PM
UbErKoOl B5's Avatar
both i believe, the firing for the coil is; 34 if im not mistaken
25
16
Old Jun 27, 2013 | 02:59 PM
*34
25
16
Old Jun 27, 2013 | 03:14 PM
I was looking for the diagram online since my haynes manuel only shows the pattern for the 2.8dohc 98+
Old Jun 28, 2013 | 08:27 AM
All fuses checkd and intact, any additional suggestions prior to Monday would be greatly appreciated
Old Jun 28, 2013 | 09:23 AM
MagA4's Avatar
UB,
Haven't been on here in a while but just came on to browse and saw this. Are you having drivability issues? Could this be caused by a faulty MAF?
Old Jun 28, 2013 | 10:38 AM
a faulty maf woud throw p0102 code and would run more efficiently/smoother if the maf is unplugged right? I have had maf issues before, doesn't seem to fit the descripton. Will definitely attempt to clean it using the rubbing alcohol + zip-lock baggy method though, thanks for the input
Old Jun 28, 2013 | 03:12 PM
Pulled, inspected, and cleaned maf. I let it dry and plugged in 1.5hrs later and no change behavioraly unplugged or plugged in. Will post updated codes later. It was recently suggested by a member of Audizine that the timing may infact be off.
Old Jul 1, 2013 | 05:16 PM
  #18
MagA4's Avatar
Hi, were you able to resolve? If so what was the culprit?
Russ Heinrichs
Aug 18, 2021 12:39 PM
black02TT
Apr 15, 2008 04:03 PM
JOnJOn
Feb 10, 2008 11:06 AM
Audiaddict
Jan 6, 2008 02:57 AM
