(update with codes) boost issue..still not fixed out of ideas and possible iusse with forge 004
Old Mar 3, 2008 | 04:02 PM
TeeterTawter's Avatar
Default RE: (update with codes) boost issue..still not fixed out of ideas and possible iusse with forge 004
Engine fault codes
17535-fuel Trim; Bank 1 (mult): System too rich
p1127-35-00 - -
17743- Engine Torque Monitor 2: Control Limit Exceeded
p1335 - 35-00 - - - Intermittent
Old Mar 3, 2008 | 04:11 PM
chaos92287's Avatar
ouTTie914 was having problems with that code and her epc light. think she switched from an n75 to a mbc and hasn't had problems since
Old Mar 3, 2008 | 04:17 PM
A4speed's Avatar
Brain, as much as i like ur avatar, i miss you stewie one
Old Mar 3, 2008 | 04:51 PM
chaos92287's Avatar
yeah, i always get complaints when i switch. but i've just had it for way too long.
Old Mar 3, 2008 | 05:26 PM
installed a mbc just now, will see if that helps rid of the EPC.
I think i do have a vacum/boost leak, sits at 16 for vacum, and now i hear a constant hissing sound coming from the back of the engine near the firewall. goin to try a different method of connecting my boost tester to it. instead of the tip, im goin to use the pipe off the cold side of the intercooler to the tb. also goin to try a different spring/washer in the 004.
Old Mar 3, 2008 | 06:45 PM
turbo kraut's Avatar
Tech Guru
somethinng else i do and always recommend, if all else fails, take it to the dealer, pay them 60 bucks to find the issue and fix it yourself
i have saved hundreds doing that
Old Mar 4, 2008 | 09:42 AM
patty AT forge's Avatar
Another thing to try is connecting the 004 direct to manifold pressure, that is to say bypass the pressure tank that controls the valve (if your car has one that is...). I've heard of the solenoids going bad and causing the valve to behave oddly.
Old Mar 8, 2008 | 03:52 AM
  #18
ouTTie914's Avatar
Glad the MBC fixed your P1335! As for the hissing check the connections to your boost gauge.
Had the same problem, turns out a simple zip tie was all it took (this would also explain your gauge's incorrect readings).
Sure I could search but... What N75 does your car use?
Haven't heard of this fault in any other car except the TT.
Good luck with the running rich!
rkelsey10554
Mar 11, 2014 10:52 AM
pepsicolla
Jun 4, 2008 09:13 AM
TKneedsS4
Dec 2, 2007 11:57 PM
neur0tic
May 8, 2007 01:54 PM
matt1colorado
Aug 21, 2006 11:12 PM
