upgraded turbo wont hold boost
Old Jan 4, 2009 | 04:35 PM
b5audi1.8t's Avatar
The last time i drove it today it wouldnt hold any psi it go to 5psi and drop to 0
Old Jan 4, 2009 | 04:36 PM
b5audi1.8t's Avatar
Also forgot to add the bov use to not blow off unless running more then 10psi now it blows off at 4psi
Old Jan 4, 2009 | 04:41 PM
cincyTT's Avatar
I'm make believe
a bov should release regardless of psi, otherwise you kill turbos in no time due to surge. Make sure the wastegate has a line from a pressure source (between compressor outlet to the TB) and the bov has a manifold vacuum source.
basically like this but instead of the mbc, its the n75
Old Jan 4, 2009 | 04:50 PM
b5audi1.8t's Avatar
yeah thats what i did when i changed the set up to the n75 when it was set up with the n75 the wastegate line fell off the wastegate and i put it back on and it was still only running at 5psi after it fell off but befor it fell off it was at 16psi and now it runs at 0psi like the problem keeps getting worse. so your sayin i should jus hook the n75 valve back up
Old Jan 4, 2009 | 05:10 PM
cincyTT's Avatar
I'm make believe
yes, hook the n75 back in. If you still have boosting issues, you either have a massive boost leak or you overspun the turbo and killed it
Old Jan 4, 2009 | 05:13 PM
b5audi1.8t's Avatar
ok thanks for all your help is there any noises to listien for if the turbo went bad? thanks again for all your help
Old Jan 4, 2009 | 05:18 PM
b5audi1.8t's Avatar
also forget to ask if havin the wastegate line hooked stright to the turbo will kill/harm the turbo or wastegate
  #18
somebody5788's Avatar
Originally Posted by b5audi1.8t
Yeah when i bought the car it said it was stock but it ran 16psi all gears and with the new turbo it came with its own wastegate. we had to modifie the bov and intake for the new turbo so the bov is one line in with a block plate on the side line and a horn on the other side and top small line so i dont know if the wastegate bad are the bov seals are shot are what im not all that great with audis
Sorry but that bugs me when people say that. These car's are almost like any other car... they don't run on black magic lol. Now if you say that about an RX-7 or hell even a Saab w/ the backwards engine I would take it but Audi's are no mysterious car.
Old Jan 4, 2009 | 05:21 PM
  #19
b5audi1.8t's Avatar
yea idk the dealer i bought it from said they got it from another dealer when i hooked up the boost gauge it said 16psi and no boost controller
Old Jan 4, 2009 | 05:27 PM
  #20
cincyTT's Avatar
I'm make believe
A dentist drill is usually a chewed up compressor, but that is if you actually make psi. As for location, as long as you are getting pressure source from the fitting on the turbo, you will be fine. Thats where the pressure for the wastegate is coming from on the pic i had above
