vac leak at injectors
Old Apr 15, 2008 | 11:58 AM
EOD5's Avatar
Default vac leak at injectors
hey guys, so i have a vac leak at all 4 of my injectors ... probably bad orings from age
anywho, running the mods in my sig, do you guys think i should upgrade / change my injectors to a different cc? i can adjust fuel pressure with my SARD FPR....so it would have to be something simple and not overly different so my GIAC can still control and adapt
im jus trying to get out of the 210cc and duty cycle 16.23ms limit area, if i can offset it so i stay farther from 16.23ms then ill be happier
hopefully this can help alleviate the idling misfires i have
any thoughts?
thanks in advanc
Old Apr 15, 2008 | 01:03 PM
cincyTT's Avatar
I'm make believe
Default RE: vac leak at injectors
Just change the o-rings. You wont be able to tune the injectors on a AEB car since you cant use lemmingwinks/unisettings.
Old Apr 15, 2008 | 01:27 PM
EOD5's Avatar
not even up a little? i feel liek 210cc is sooo small..
but ill do what you said...in your opinion do you believe that those leaks could be a misfire in all cyls culprit?
Old Apr 15, 2008 | 01:41 PM
cincyTT's Avatar
I'm make believe
Not even a little. The stock fuel pressure is at 4 bar so they flow more than you think. Also they can handle all the power you will be able to make with a ko3.
Not sure, but i bet anything that interupts the combustion chamber can cause a misfire.
Old Apr 15, 2008 | 06:38 PM
EOD5's Avatar
ok just ordered new O-rings for injector top and bottom, and Inserts for the Intake Manifold
also picked up an APR TIP and NewSouth IM Power Gasket.....those wont help my CEL but always a nice add on
vtraudt
Feb 25, 2012 11:09 AM
xxipsxx
Dec 11, 2010 03:13 PM
inventorA6
Apr 15, 2009 06:46 AM
MC Hammered
Feb 4, 2008 12:06 AM
