vag com codes help
Old Dec 6, 2012 | 12:29 PM
DillonT's Avatar
Default vag com codes help
hello i got the following codes. I just finally got vcds lite working. anyone offer any suggestions? and anything cool i can do with the free one?
CDS-Lite Version: Release 1.2
Wednesday, 05 December 2012, 22:03:44.
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,16,17,25,35,37,45,55,56,57,67,75,76 ,77
Address 01: Engine Labels: None
Controller: 8D0 907 557 N
Component: 1.8l R4/5VT MOTR AT D03
Coding: 06251
Shop #: WSC 01117
VCID: 3B09B4EF3A7D
1 Fault Found:
17967 - Throttle Body (J338): Fault in basic settings
P1559 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 02: Auto Trans Labels: 01V-927-156.LBL
Controller: 8D0 927 156 T
Component: AG5 01V 1.8lR4T US D06
Coding: 00000
Shop #: WSC 00000
VCID: 3E0FBDFB296F
1 Fault Found:
00526 - Brake Light Switch-F
27-00 - Implausible Signal
Address 03: ABS Brakes Labels: 4D0-907-379-ABS.LBL
Controller: 4D0 907 379 L
Component: ABS/EDS BOSCH 5 4171
Coding: 0265109043
Shop #: BB 34171
VCID: 3701A8DF0655
__________________________________________________ ____________________________
Address 01: Engine
Protocol: KW1281
Coding: 06251
Shop #: WSC 01117
Protocol: KW1281
Coding: 00000
Shop #: WSC 00000
Old Dec 6, 2012 | 05:40 PM
ImTheDevil's Avatar
Do a throttle body adaptation (search will reveal the procedure). Look up a thread about "Easter eggs" (aka hidden features) and you'll find a bunch of stuff. The best features I enabled on mine were auto lock/unlock, horn delete when arming alarm, one touch unlocking, and remote operation of windows and sunroof.
Old Dec 6, 2012 | 10:08 PM
DillonT's Avatar
ok cool, ill look that up. i dont have a remote for mine yet factory it had a fob, but i didnt get one when i bought it. going to try to do a flip key conversion.
Old Dec 8, 2012 | 07:23 AM
97a4q's Avatar
Clean the throttle body and do a throttle body adaptation. The fault code for the transmission is a phantom code since you scanned its ecu before depressing the brake peddel. It will disappear if you depress the brake peddel before you scan ecu 02!
Old Dec 8, 2012 | 11:03 AM
DillonT's Avatar
heading out to clean it now, also looking up throttle body adaptation.
Old Dec 9, 2012 | 11:57 AM
DillonT's Avatar
ugh. more codes... installed chipped ecu last night, ran great, but eventually got a slight shudder in boost/wot. i was scarred trans was issue (autofail) but no trans codes. i got these:
Controller: 8D0 907 557 P
Component: 1.8L R4/5VT MOTR AT D02
Coding: 06251
Shop #: WSC 06335
VCID: 3D0DBAF72469
6 Faults Found:
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
18089 - Shareware Version. To Decode all DTCs
P1681 - 35-00 - Please Register/Activate
16684 - Shareware Version. To Decode all DTCs
P0300 - 35-10 - Please Register/Activate - Intermittent
16688 - Cylinder 4: Misfire Detected
P0304 - 35-10 - - - Intermittent
P0300 - 35-00 - Please Register/Activate
16688 - Shareware Version. To Decode all DTCs
P0304 - 35-00 - Please Register/Activate
Readiness: 0010 0001
seems like i have a misfire issue. plugs are like a month old. i put them in when i did timing belt and vc gasket. im going to go check the gap, and hopefully set down to .028" for the chip
markymarc
Sep 8, 2010 01:59 AM
joenelson7687
Aug 25, 2010 04:10 AM
Ruggedboy
Jul 20, 2007 11:30 PM
supercoupe91
Jul 13, 2007 06:20 PM
rafa_207
Jun 27, 2007 01:31 PM
