Vag-com error meaning?
Old Aug 15, 2012 | 02:56 PM
shango11's Avatar
Default Vag-com error meaning?
So as some of you may know I've been having some problems with my car, after changing the water pump and an engine oil line I took it for a drive and it was shifting weird so I took it back home and let it sit overnight. This morning I turned it on and tried to see what the problem was and it seems the car will only go into gear once I reach 2000rpm, this means that if i put the car into reverse I have to hit 2000rpm for the car to move back slowly, same for drive. I don't know if the car will shift into second gear as I can't really drive it. I tried leaving the car on so it would warm up and I tried again but I got the same result.
I ran the vag-com and sure enough I got an error code:
17114 - Gear Ratio Monitoring: Incorrect Gear Ratio.
Any ideas on what it might be?
EDIT: Automatic transmission 1.8T Quattro
Old Aug 21, 2012 | 01:14 PM
jeckel20003's Avatar
Old Aug 21, 2012 | 02:52 PM
shango11's Avatar
Hopefully is the low transmission fluid, I've been trying to get it to a shop but something else keeps popping up, hopefully I'll be able to take it in tomorrow or by the end of the week.
BgsaundersA4
Jul 22, 2014 01:33 PM
tultalk
Jan 12, 2014 07:04 PM
ThatRetardedKid
Feb 3, 2012 05:52 PM
cindyr8r
Nov 17, 2008 02:39 AM
