AudiForums.com
-   B5 Models (https://www.audiforums.com/forum/b5-models-69/)
-   -   VAG-COM issues with central lock recoding (https://www.audiforums.com/forum/b5-models-69/vag-com-issues-central-lock-recoding-140689/)
rockblock Oct 21, 2009 09:23 PM
Greetings,
I wanted to test my new interface using the 409.1 software. My goal was to recode the central locking system. The interface works well, it reads all codes, deletes/resets faulty codes, but when trying to recode the central locks, after hitting "do-it", it reverts to the original value (I am trying to get 16172 to change to 15208). I'm not sure if replacing the stock radio with an aftermarket unit has anything to do with this...
Any help would be greatly appreciated.
Thx
Andrew149 Oct 21, 2009 09:36 PM
that is weird mine didnt do that i have a 1999.0 and a aftermarket radio i didnt change anything in my car
rockblock Oct 21, 2009 10:23 PM
hmmm...are you using 409.1?...I tried at least 10 times...and no matter what numbers I key in, it reverts back to the original value...
TeeterTawter Oct 21, 2009 10:52 PM
are you doing it the same way as posted on the ross-tech website?
here is the "radio issue" http://www.ross-tech.com/vag-com/aftermarket-radio.html
recoding info http://www.ross-tech.com/vag-com/cars/audiB5.html
Andrew149 Oct 21, 2009 10:57 PM
408.2 or somthing with 408
rockblock Oct 22, 2009 10:06 AM
Yes I am...it's reading the #35 module, pulling all up all info for VAG, Soft Coding, Component & Shop. Then I select recode, key in my new code under Workshop Code, click "Do It!", screen clears and then, instead of seeing the new code being read, the original info is being displayed (looks like it's trying to write, but in fact it doesn't)...
