Vibrations 65-75 mph
Old Jun 5, 2010 | 11:21 AM
vtraudt's Avatar
Default Vibrations 65-75 mph
After changing the clutch and installing the summer tire/wheels, I noticed vibrations at 65-75 mph.
I had the tires balanced, but the vibrations still exists.
Shifting in neutral won't change it.
Could it be the drive shaft?
How to narrow down the problem source?
Old Jun 5, 2010 | 11:56 AM
FASTER's Avatar
Tech Slut
you could try switching the "more true" wheels to the front. Make sure there arent any bubbles in the tires. Make sure your lugs are torqued correctly and evenly. Make sure all the wheels have hubcentric rings on them, (cuz it sounds like they are aftermarket). It would be weird that any suspension or alignment changed at the same time, but id start checking that next.
Old Jun 5, 2010 | 11:58 AM
FASTER's Avatar
Tech Slut
Also i hope you aligned your clutch disc properly when you did the install, but im leaning more toward a tire/wheel problem.
HolyokeAudi
Sep 17, 2014 08:21 AM
Screedman
Sep 1, 2012 04:34 PM
murdox
Oct 27, 2011 07:32 PM
carnut65
Jun 8, 2009 05:40 PM
1.8BEASt
Mar 24, 2009 10:22 PM
