Originally Posted by ObnoxiousDrunk
(Post 1165491)
gonna have to look into the Hawk HPS pads for my next change then......anyone running the A8 upgrade with these? Any difference between other pads you may have used prior? I have no issue with the pads I'm running now, but if it can be better with a little less dust.....
don't want to threadjack...... |
Yep, I'm running Hawk HPS with drilled/slotted A8 brakes. I bought them all at one time so I haven't tried other pads with them but I doubt I will. The combination is great and stops right-frigging-now when you hit the pedal. I'd recommend this setup to anybody.
Gentlemen thanks for the quick replies, that's all I needed to hear.....when the tulips pop, I'll be changing pads for some Hawk HPS. Along with all other spring maintenance.....too long a list.
Glad that I could help and for once AFers actually agree!
Tell me about it - my inspection is due by the end of May. I have a laundry list too - gotta do front CAs, rear pads and rotors plus one slider bolt, fuel sending unit, outer TREs, and adjust my ebrake cables to get the ebrake functional again. Then I need to find my next set of wheels, paint my roof black, pick up/paint/install my S4 bumper, dial in my rear coilovers, put in a short shifter, finish my suede interior...it never ends. Thankfully:)
(Post 1165507)
i ran hawks on previous cars. i need to go through my records and see what i have on there. i am hoping the rotors are still good. thanks for the insite everyone.
Nobody can recommend the correct pads for you without knowing your driving style... is it a easy DD? do you do hard canyon runs? auto-x? track days? spirited daily? the Hawk HPS pads are a good DD pad, but they're more auto-x and twisties oriented. I'd go with mintex red box pads for a spirited DD.
just curious OP... r u from stanislaus county? if so where at? im from hughson
ebc green stuff all the way!
