AudiForums.com
-   B5 Models (https://www.audiforums.com/forum/b5-models-69/)
-   -   what is this intake hose? What's it do? (https://www.audiforums.com/forum/b5-models-69/what-intake-hose-whats-do-131093/)
Pa Matt Apr 30, 2009 11:00 PM
1 Attachment(s)
This isn't my setup, but i just put a K&N panel filter in and swiss cheesed the airbox. I noticed this line(The one that the tiny filter is attached to) is broke leading to some type of pump or something. What the heck is this? Something for emissions?
Attachment 45178
Mike-2ptzero Apr 30, 2009 11:45 PM
It goes to the secondary air pump that sits below the air box and feeds air thru one of the hard pipes that sits above your exhaust manifold to the valve sitting on the back of the head on the exhaust side.
Pa Matt May 1, 2009 07:42 AM
Is it something I need to replace if its cracked/broken on the lower side? Open air goes to it still obviously...
Tweaked May 1, 2009 09:13 AM
You should. The pump should be pulling in filtered air as not to destroy it.
Pa Matt May 1, 2009 11:21 AM
okay, I'm not gonna go oem and pay out the whazooo, but I'll get a patch piece to clamp/tape onto the broken section. Thanks for the help! What exactly does that air pump do? I'm new to audi's. I've owned, built, turbo'd many honda's and they don't have anything like this!
Mike-2ptzero May 1, 2009 11:36 AM
It blows fresh air into the exhaust side of the head just behind the exhaust valves.
Pa Matt May 1, 2009 04:20 PM
ah, gotcha. did some reading and found that it helps with cold starts
Mike-2ptzero May 1, 2009 04:42 PM
Helps for cold idle since it doesn't come on right as you start the car.
Tweaked May 2, 2009 01:13 AM
It's mainly for emissions. It helps the cat light-off on cold starts and is also used to test the O2 sensors.
BoostinginmyB5 May 3, 2018 10:57 PM
Attachment 45178
What size and degree of elbow did you use for that??
