Wheels stuck to car?!!
Old Mar 9, 2011 | 02:14 PM
audiA4gm's Avatar
Default Wheels stuck to car?!!
Hi guys, I was scheduled for a brake job and get this...Monro couldn't get my rims off. They are apparently completed corroded to the car...The mechanic said he broke 3 sockets...he said heating them up might be a way to remove them...but I have never heard of such a thing. I was scheduled for shock replacement (private mechanic) and the brake job (from monro) and now I'm in trouble.
If anyone has any advice it would be an enormous help. I can't believe what I'm hearing, but I haven't had the wheels off in about 8 months because the car has been running well.
Old Mar 9, 2011 | 02:20 PM
JASEA4's Avatar
unfortunetly it can some times happen , the studs corrode into the hub,
one of my back studs took nearly an hour to remove, got there in the end after bending a wheel brace.
give them a good soaking with a lubricant for a couple of days.... when you do get them off but a thin coat of copper grease on them
Old Mar 9, 2011 | 02:48 PM
CCA4's Avatar
Happened to me on my 97. The wheel corroded to the hub. I just hit the **** out of them with a dead blow until they came off
Old Mar 9, 2011 | 03:02 PM
audiA4gm's Avatar
Will do guys...gonna soak the **** out of them w/ W-D 40 for the next couple days and I Just put the car in the garage w/ a heater. Hopefully this works out!
Old Mar 9, 2011 | 03:22 PM
99A4NOW's Avatar
This happened to me too, but I think the OP is having trouble with the lug nuts. A good quality Snap-on brand impact socket with a breaker bar would presuade them to come off- tell Monro to quit using cheap sockets!
Old Mar 9, 2011 | 03:49 PM
CCA4's Avatar
gotcha. OP, don't use WD-40. On the grand scale of penetrating oils, it sucks. See if you can get your hands on some PB Blaster or Kroil. Those are much better suited to this task.
Old Mar 9, 2011 | 04:15 PM
Gambit0714's Avatar
+1 on that PB Blaster, a good quality impact socket, and a breaker bar. That should do the trick.
Old Mar 9, 2011 | 04:21 PM
audiA4gm's Avatar
thanks guys, I'll pick up PB blaster tonight.
I need these f'n wheels off! Just found 4 used s4 struts w/ only 48k miles on them for $160...and the seller will install for $200. Really cool avid audi owner, he's been a huge help.
Also getting all brakes done for $440. I'd be halfway done if these wheels could come off, gonna keep trying!
Old Mar 9, 2011 | 08:11 PM
MiamiA4guy's Avatar
........+1
Old Mar 9, 2011 | 09:50 PM
audiA4gm's Avatar
I've been PB blastin the shitt outta them, every time I drive and park.
