When to change differential fluid
So I am just curious how often I should be changing my differential fluid?
RE: When to change differential fluid
i dunno how often...i'll figure it out sooner or later. check your rear differential fluid for leaks as well. mine seem to have a bad gasket and will require changing soon.
I read that the diff fluid is supposed to be a 'lifetime' fluid, and doesn't need changing (unless it's leaking or something). But I changed mine anyway and felt anoticable difference for the good. Smoother shifts!
| All times are GMT -4. The time now is 08:07 AM. |
