Where should I tap to get power?
Old May 14, 2010 | 04:18 PM
mikekey's Avatar
Default Where should I tap to get power?
I need to tap a power wire that is only hot when the ignition is turned on, and can support my two LED headlamps. I don't feel like wiring a switch all the way inside the car and I don't want to wire it into the headlamps or parking lamps.
Anyone have any suggestions?
Old May 14, 2010 | 04:41 PM
jt's A4's Avatar
cd player
Old May 14, 2010 | 04:49 PM
mikekey's Avatar
Originally Posted by jt's A4
cd player
dude, that's running it into the inside of the car, I'm talking about the engine bay bro. Thanks anyways.
Old May 14, 2010 | 08:14 PM
CCA4's Avatar
I guess I'm confused, the lowbeams are only hot when the ignition is turned on, are you tryin to wire up the LED's seperately?
Old May 14, 2010 | 08:15 PM
jiggleo's Avatar
if you're putting in led lamps what's wrong with the original headlamp wires? There's also a relay/fuse box under the hood right up by the windshield driver's side. A test light will do wonders.
Old May 14, 2010 | 08:25 PM
mikekey's Avatar
These kind of LED's. The low beams are only hot when the light is turned on. Only two wires going to the lows, a ground and hot.
I'll check the fuse box, never noticed it, must be under one of the covers.
Old May 14, 2010 | 08:31 PM
CCA4's Avatar
Ohhh gotcha. Sorry man, didn't really know what you were gettin at. So you wanna be able to run the LED's completely independent of the low beams right? Just a shot in the dark, but how about the radiator fan lead, that's only hot when the key is on, right?
Old May 14, 2010 | 08:52 PM
mikekey's Avatar
Guess it's voltmeter time.
suuntotim
Jul 25, 2011 12:36 PM
99BlackA4
May 22, 2006 08:43 PM
