whining noise when pressing the clutch
ive just noticed the last few days on my 97 audi a4 158k miles that when i press the clutch i during a gear change there is a slight whinning noise (thought it was the missus at first as shes always whinning) but it did it when she wasnt in lol.
im thinking maybe the thrust realse bearing or maybe low on gearbox oil but this is my first audi so any ideas any1 before i start strippin stuff i dont need to....cheers
Could very well be the throwout bearing. Transmission oil is easy enough to change, definitely start by trying that. There are various DIYs floating around, and ECS tuning has a nice kit for it.
How old is your clutch?
I used to get a squeak noise that sounded like a rusty door hinge when I would push in my clutch. Flushed the clutch/brake fluid and it went away. Is it only when changing gears while the car is moving or can you just sit in it in your driveway and pump the clutch and reproduce the noise?
It could certainly last that long if it hasn't been mistreated. Does it make the noise if you push the clutch pedal and rev it up while stopped?
Can you hear it if you pop the hood while it's running?
If it makes the noise all of the time (even when stopped?), and not just when the clutch is pressed, then I would think that it's something other than the throwout bearing/transmission.
