window and lock questions
Old Nov 13, 2012 | 07:05 AM
96whitea4's Avatar
Default window and lock questions
Okay so some may know that I had a few window/ lock problems in the past.
Yesterday I had the doors apart (amazing how the whole window frame comes off btw). My door latch on the drivers rear door doesn't release when the interior door handle is pulled. I am going to get another latch unless there is some fix for this.
The passenger rear door window does not go up or down with either of the switches, should I be looking at a regulator/motor? All the wires/vacuum look good on both doors.
thanks
Old Nov 13, 2012 | 07:57 PM
mtroxel's Avatar
I've driven 440,000 miles in B5's and had this a few times. Just take the latch out and clean it out and put some new lithium grease in it. It gets gummed up. Especially on a 96 - 99.5 B5 before they added a baffle in the door to direct air stream away from the lock.
Old Nov 13, 2012 | 09:39 PM
96whitea4's Avatar
thanks will give it a try tomorrow
Old Nov 14, 2012 | 08:08 PM
96whitea4's Avatar
well i had the door apart again, took the latch out. cleaned it up the best i could and re-greased it. still a lil sticky. Will see what happens once the grease works into it.
thanks
deener86
Mar 14, 2013 01:52 AM
vegastt
Sep 11, 2007 01:52 AM
IzeBerg
Apr 5, 2007 01:58 AM
auS4di
Jun 17, 2006 01:59 AM
02A418T
May 12, 2006 12:04 PM
