windows wont work!!
alright so i got a 01 a4. was driving home from work went to put up my windows and they wouldnt work. about 4 hrs before this they worked fine and never had a problem with them at all. none of the switches or windows work from any door or switch. i poulled the driver side door panel off since the master switch is there. no broken wires. all the harness's are hooked up. checked the wires that go from the door into the car in the bplastic boot. and no broken wires. checked all the fuses even the ones that dont have to deal with the windows. nothing blown at all. my power locks and mirrors still work just not the windows! idk whats going on! and i need some help.
thanks |
Are you still active??
You are the only person I've found in all of the threads that seemed to have exactly the same problem I do. None of my windows move, switch has power, no sound from anywhere in car when any window is tried. Fuses all good, locks all work, door connections appear dry, and solid.
Did you ever get an answer or find a solution on your own after 6 years or searching, or did you give up? |
| All times are GMT -4. The time now is 06:15 AM. |
