wiper problems
Old Feb 17, 2011 | 11:09 AM
MARKANTO13's Avatar
Default wiper problems
So, this morning I put on the wipers and they worked fine but when I turned them off they didn't stop at the bottom of the windshield like normal. They stopped all the way up. Any thoughts?
Old Feb 17, 2011 | 08:46 PM
NHolzschuh's Avatar
try popping the hood, then look at the base of the wiper arms, theres a round cap.
pop off the cap, loosen the bolt.
pull the arm down to the base(starting point). tighten the bolt.(do this to both)
try your wipers
if problem persists... motors id assume. idk if this is a perfect way of testing them, but its what i would do.
Old Feb 20, 2011 | 03:15 PM
MARKANTO13's Avatar
replaced the relay and now the fuse keeps blowing.
Old Mar 7, 2011 | 10:17 AM
chasb1973's Avatar
Any luck?? I have a 99 avant with the same issues.. Wipers stop in the spot you turn them off.. Intermittent setting pause straight up but work fine other wise...
fcamargo6thave
Dec 30, 2008 01:37 PM
pearlescent
Dec 25, 2008 08:28 PM
gordond
May 9, 2008 03:10 PM
93typhoon
Feb 22, 2008 02:10 PM
jpperry
Apr 12, 2007 11:31 AM
