Zero Dust Performance Brake Pads?
I've always been under the impression that if you change to a different type of pad, you have to have your rotors re-surfaced. It has to do with the way the pad seats into the rotor after time.
Avoid YellowStuff. They suck on the street. RedStuffs make just as much dust as GreenStuffs, but add in a noise factor.
Pretty much any ceramic pad will reduce the dust factor, but you'll wish they weren't so noisy and you'll notice a reduction in bite and an [I]increase[I] in stopping distances under normal traffic conditions.
I can't say this enough: Best pad for your money right now is still Hawk HPS. Lower dust than most "performance pads," can take a beating from the weekend AutoX, and will stop better than OE pads under all conditions.
If the rotors are in spec for run-out and thickness, not heat-cracked or spotted, and don't have an excessive lip on the edge, leave them alone. If they fail any of the above test, replace them.
I've had akebono euro ceramic pads for the past year on mine. Huge improvement in brake dust (much less and it's a light brown color that doesn't really show up). Only downside is that the brakes don't have the same initial bite as the OEM pads. Overall braking performance is good, just more progressive and less bite.
Good luck.
Tom
Good luck.
Tom
I'm thinking I'll probably go with Hawk HPS.
I haven't measured the thickness of the rotors yet, but I noticed they do have quite a lip on them. You're saying I shouldn't bother resurfacing them and just replace them? What's the best replacement for them? Drilled, slotted, etc? or should I just go with OEM?
I effing hate ceramic pads. As stated above, they will reduce brake dust and noise (for a while) but the down sides aren't worth it in my opinion.
Increased braking distance, increased pedal effort, increased heat applied to the rotors resulting in warped rotors, the pads crack and chip off if overheated, and they scream like all hell when they start the crack.
ive had ebc before and they were alright, greenstuff is kinda an organic pad but very good, and redstuff is full ceramic, they put off brake dust but not alot and its light colored so i can go upto 2 weeks with cleanish rims.
#19
Crossed drilled are useless for street cars. New pads are so advanced, you'd melt the calipers into puddles before you could cause the pads to gas. Slotted just chops the pad surface, significantly reducing pad life and increasing noise (sounds like a Jake-Brake on a truck coming down from the highway). Additionally, both of these rotors have mass and surface area removed from them, decreasing the heat-transfer abilities of the brakes, which in turn can lead to fading or warping.
Blank rotors will have the best feel and performance for street or weekend track use, and are usually the easiest on the wallet, too!
As for EBC, Greenstuff is just an OE style replacement. RedStuffs stop well for the street, but they are noisy and eat rotors for breakfast, lunch, and dinner. Hawk HPS wasn't available for my 02 Jag X, so I used RedStuffs, the whole time wishing I could get Hawk HPS for the car. They were pretty good coming down off the front straight at Limerock, but every day driving situations weren't as inspiring. If Hawk is available, I'd recommend them over the RedStuffs any day.
#20
I never really considered that TT/A8 brake mod in the past, but I think I'll look into it now. Is it relatively easy to do? How much will I end up spending on all the parts, discs, pads, etc? Is it just for the front, or should I use this mod on the rear brakes too?
