1.8t BFB Rebuilt throws code 17536 - MAF?
Old Jul 17, 2013 | 06:14 PM
KristianRanta's Avatar
Default 1.8t BFB Rebuilt throws code 17536 - MAF?
Just rebuilt (complete head work), driven about 2000km and has worked fine until now, feels a little slow (not close to 163hp) and has always done since I got it, but never had time to look it up, until now, before this it never gave me CEL.
But a couple of weeks ago I got code 17536 (P0171 in Generic OBD), cleared and since then no CEL.
So I logged all the things I could with Autodata today and Lambda sensors seems fine, both show 0.1-0.8v.
Had some strange sound from the fuelpump so I took a closer look and found the hard return hose being bent inside tank so fixed that and got a new fuelfilter and sound went away.
Yesterday I was driving home from a trip and CEL turned on almost as soon as I started to drive (yeah always something wrong when your going home from a trip ), got code 17536 again, cleared it and drove about 400km without a problem. Today it felt really laggy and light came on again, its hesitating and feels really slow!
Autodata info gave me:
All air / water temps fine
MAF about 80-90G´s at 5500rpm full throttle 2nd - 3rd gear.
Lambda sensors respond as they should
Turbo pressure about 1550millibar
Tried to pressure test all hoses but I probably did it wrong because I couldnt get the system to keep pressure all the time because I didnt plug anything, it still held pressure pretty good. I guess some of the valves and hoses open up and let air rush into the intake (like the green/black valve that dampens the air).
I´m thinking bad MAF but what more could I check before I go and spend money??
Old Jul 18, 2013 | 08:30 AM
Forgot that MAF gave me 1.47g's on idle
Old Jul 18, 2013 | 05:34 PM
Also got a: 17699 - Coolant Temp Sensor at Radiator Outlet (G83): Signal too Large P1291 - 001 - Upper Limit Exceeded
that wont go away, tried new sensor without luck..
Did some more testing tonight, VCDS Lite showed MAF G´s to about 120, so MAF should be OK?
But also noticed something scary, my Lambda was 1.14(!) when driving hard 2nd - 3rd gear!
Old Jul 19, 2013 | 04:14 PM
Ok Temp sensor fault is gone, PRV and Jet suction pump changed.
I can now hear the "PSHHH" I never had before
But still feels laggy.
Looking around I found that B1-S1 (o2 sensor 1) shows sometimes over -10% on idle and on block 033 it says like 1.540v.
Is that correct, shouldnt voltage be like 0.1-0.8??
I think if the voltage would be so off it would light CEL?
I´ts a Lean problem, because when logging with VCDS lite Lambda hits up to about 1.250 at 3000rpm.
Boost leak test OK, the only thing I can hear now is bubbling in the oilpan as I test for leaks.
Old Jul 20, 2013 | 01:21 PM
Now with VCDS log, someone, please?
LOG-01-002-031-032.CSV - Speedy Share - upload your files here
Old Jul 24, 2013 | 10:16 AM
Problem found!
Pressure at Rail - 2.5 bar idle / 2.3bar at 2000rpm
Pressure directly from pump - 2.3 bar / idle
So, what aftermarket pumps fit my car?
I tried to measure the pump some week ago and it was about 123-125mm high.
nickmercedesbenz
Feb 7, 2014 06:11 PM
Streetstamps
Mar 23, 2013 08:28 AM
carbon audi
9
Sep 2, 2011 09:46 AM
littlenico
Jul 17, 2010 05:35 AM
alias747
Mar 4, 2008 05:18 PM
