1.8t lack of engine power
Old Jun 3, 2012 | 04:42 PM
angelyno55's Avatar
Default 1.8t lack of engine power
Hey guys
I have this 02 A4 1.8t that does not want to cooperate when i push the gas... I worked on the engine about 500 miles ago. timing belt, water pump all that, oil pump, rebuilt the turbo. ran good, but suddenly just got lazy. does not have power. it's like the turbo does not kick in. it'll gain speed, but when i hit the padle won't jump at all. seems like it cicks back... replaced spark plugs, but no changes. turbine shaft is spining easily with minimal play. can i test the boost pressure with vagcom? can be also the fuel filter? no check engine light on...
I wana sell this car, too many problems with it.
Any help will be greatly apreciated !!!
Old Jun 8, 2012 | 10:15 AM
Dozanti's Avatar
Best bet is to buy a cheap mechanical boost gauge (if you plan to sell) and double check boost/vacuum. Also, it is possible after having the timing belt done and it running fine, that it jumped a tooth or two, reaffirm that it is in time still as well
Old Jun 9, 2012 | 01:36 PM
angelyno55's Avatar
Thanks for your answer. I solved the problem. It was that valve that is atached to the turbo (i don't know what's a called)
Old Jun 9, 2012 | 02:35 PM
olstyn's Avatar
Diverter valve, or maybe you mean the wastegate. I take it one or the other was stuck open so you were getting no boost?
Old Jun 9, 2012 | 03:50 PM
Dozanti's Avatar
N75 valve ?
Old Jun 10, 2012 | 02:21 PM
angelyno55's Avatar
yeap, that's right. was open. the spring from inside of it was broken or don't know what happend with it, bt i was loosing all the boost.
mike 74
Feb 27, 2013 02:37 PM
goldy1234
Jul 19, 2009 06:47 AM
louis2035
Apr 6, 2009 09:45 PM
A4Guy23
Aug 28, 2008 10:17 AM
t42ayj
Jun 30, 2004 01:44 PM
