2003 A4 3L Quattro Oil Light
The red blinking lamp means thre is no oil pressure and you should not run the engine. However it could also be due to a bad oil pressure sensor or wiring problem. You may want to verify the oil pressure with a mechanical test gage.
Follow up
Just a follow up. I had to take the car to the dealer because it needed a new ignition coil (found out after they had it already). They cleared the codes and it hasn't appeared since. I've probably driven 2,000 miles since then. So I think it's alright. They read the codes and didn't say anything to me about the light.
Now I have to fix my exhaust which decided to fall.
crazybk187
08-05-2013 04:29 PM
DJPhaze
12-26-2012 05:57 PM
inkhaton
08-16-2012 03:37 PM
