2003 B6 A4 Radio Reception Fix - AudiForums.com
Reply
Thread Tools Search this Thread
Old 03-05-2012, 03:38 PM
Default 2003 B6 A4 Radio Reception Fix
Tried to make the thread title as descriptive as possible since I had to do quite a bit of googling before coming across this gem. Long story short, wife's 03' A4 has had terrible radio reception for some time. Through several threads I found it was the "receiver" (or whatever you want to call it) that is located under the rear headliner and controls which antenna (these cars have 3) to use based on optimal reception. Anyway, these things are prone to cracking which you've probably found if you're experiencing this problem. They're about $350 new and hard to find in working condition used and are essential to having anything but the bare minimum of reception. After looking for a solid solution for some time I came across this one: Easy Cracked Radio Reciever Fix and while I know it's a cross link to another forum, the guy deserves credit since the method is well documented, pictures are great and it will end up costing you somewhere between free (take the clips from the office) and about $1 if you buy them in a store. Pretty awesome to have perfect radio reception again in about 10min worth of time. FYI I left the "receiver" in place while pressing/testing it for a good connection and then popped it off to put the binder clips on. The spot mine needed them was almost exactly the same as in that thread so I'd recommend trying there first. I used the "small" version of the clips (they usually come in 3 sizes). Hope this helps!
Old 04-07-2012, 10:23 AM
CRF Rider 57's Avatar
Great info ...Thanks!
Wifes aftermarket Alpine has poor reception - took it out of the dash, played with the antenna connections and it actually got better reception disconnect from the antenna connection. This may be the problem!
Old 04-27-2014, 04:36 AM
sbardill's Avatar
Default Audi A3 Radio poor reception (2003)
Dear Audi owner,
I would like to try the clip fix on my A3.
Can you tell me which trim headlining to pull back as it isn't too clear in the thread.
Cheers,
Steve B
Old 04-28-2014, 06:57 PM
Quote:
Originally Posted by sbardill View Post
Dear Audi owner,
Cheers,
Steve B
I'm not sure if it's the same in the A3 but in the A4s there is a piece of plastic trim where the rear windshield meets the roof fabric inside the car. If you pull that off you'll see the radio antenna distribution circuit board referenced in the picture in the linked thread. Again, I can't say for sure if it's the same in an A3 but this is where it is in the A4s.
Reply
Thread Thread Starter Forum Replies Last Post
No Radio Reception philip_pressdee Electronics 2 03-11-2013 04:44 AM
Radio Reception 4drA4quattro General Tech 0 06-06-2011 11:44 PM
2003 A6 poor radio reception pinetown General Tech 0 08-15-2010 05:31 PM
no radio reception r1chp Audi A4 17 12-12-2007 07:41 PM
AM/FM Radio Reception webbie General Tech 2 10-09-2007 01:39 PM
Tags
2003, a4, audi, b6, bad, clips, crack, fix, problems, radio, receiver, reception, steroeo, tough, upgrade
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Advertising
Featured Sponsors
© 2018 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
