2006 a4 cab. Footwells filling with water
2008 A4 passenger side rear footwell wet after rain
Did you find your answer. Just purchased a low mileage B6 A4 Cabriolet and the passenger side rear floor gets very wet when it rain. Also when washing the car. Haven't had much time to investigate further.... Any help would be appreciated. Thanks
Leak
It turns out that the previous owner had the same issue and had a local repair shop deal with it.
If you cycle the top until the tonneau raises, you will see a drain under the front (both sides) of where the cover seats. You will see a drain hose below it leading to the bottom of the car. If you get under the car (use jack stands and be safe) you should see where they drain, just forward of the rear wheelwells, probably covered up by mud and road dirt. This seems to be s common issue. My foot wells were taking on an inch of water!
I got rid of my problem, before having a chance to fix it by wrecking my 06 and replacing it with an '08 B7 with 26K miles!
Nuglets
11-12-2021 07:28 AM
